Activity › Forums › Adobe Premiere Pro › Does Mercury Transmit send super-blacks?
Posted by Drew Lahat on November 15, 2019 at 11:57 pmPremiere’s built-in monitors and its scopes ignore blacker-than-black blacks (aka superblacks), or 4-63 values in 10bit SDI terms.
But does it process and send them out via Mercury Transmit (specifically with Blackmagic SDI cards and boxes)?Drew Lahat replied 6 years, 10 months ago 3 Members · 6 Replies -
Pat Horridge
November 16, 2019 at 9:19 amDon’t know the answer but isn’t it Super Whites and Sub Black’s.
Pat Horridge
Broadcast & Post Consultant, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
pat@vet.co.uk -
Chris Wright
November 19, 2019 at 12:58 amthe YUV scopes use legal range. all the other scopes are full range. premiere itself uses full range.
with certain hardware boxes, it can goes from 100 nits to 1,000 nits.
https://community.adobe.com/t5/premiere-pro/faq-setting-up-for-hdr-work-in-premiere-2019/td-p/10646406 -
Drew Lahat
November 19, 2019 at 1:04 amThanks for the reply, Chris, but none of it answers my question. ☺
Indeed, in the scopes you don’t see sub-blacks. And with the hardware boxes & cards, I’m not talking about HDR or nits, but about Rec.709 sub-blacks bit values.
Anyone who uses Premiere with a hardware box and knows what a SMPTE PLUGE is should be immediately able to answer.. -
Chris Wright
November 19, 2019 at 1:23 amas i said, full range is 0-255 which is all values including sub blacks.(below 16) and superbrights(above 235) that’s how premiere works, both in its engine and mercury transmit. however, mercury transmit’s color primaries are hard coded to rec. 709.
