Activity › Forums › Apple Final Cut Pro › Does Match Color have a trick to making it work?
  • Jeff Kirkland
    November 7, 2018 at 8:50 pm
    It works best when the frames of each clip are roughly identical but even then it’s hit and miss. Basically it’s a nice idea that doesn’t work all that well. The same feature in Color Grading Central’s new CinemaGrade plugin is more reliable – but only just.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Kyrina Bluerose
    November 8, 2018 at 6:26 am
    thank you for the response.
    comforting it’s not me
    disappointing that it doesn’t do what it is supposed to do.
  • Joe Marler
    November 9, 2018 at 4:31 am
    I formerly used Hawaiki Automatch, which worked pretty well. You pick several match points of different colors, and it has lots of tuning controls. I haven’t used it in a long time because I just match shots manually now.
    It was harder to use for multicam due to some UI issues; that’s the main reason I quit using it.
    https://hawaiki.co/automatch.html
    Just using FCPX you can have two side-by-side clips and waveforms, however one must be in the Event Viewer. This tutorial demonstrates how:
    https://www.youtube.com/watch?v=yhsmDh29xk4
    In this video Larry Jordan shows how to crop to a patch of skin and use the vector scope to adjust skin tone. You can use this technique to match skin tone between two clips:
    https://www.youtube.com/watch?v=jX45Yi1spY4
  • Kyrina Bluerose
    November 9, 2018 at 9:11 am
    Thank you!
    Haven’t learned any color correcting yet so hopefully this will be a good intro. I’ve just been trying to use the basic dots in the inspector and eyeball it. Looking forward to learning how to bring two clips into the viewer for sure – that would be helpful in many cases. Hopefully I’ll be able to use FCPX again soon.
    Much appreciation for your sharing your admirable knowledge!
