Activity › Forums › Apple Final Cut Pro Legacy › Does Log & Capture Create a Log? Can I save Reel Content…?
  • Does Log & Capture Create a Log? Can I save Reel Content…?
    Posted by Sebastian Knight on April 25, 2005 at 6:16 pm
    I am beginning to Log & Capture. I was wondering when I set-up to Log and Capture is there some type of Log created, and if so can I use it to Log reel contents? So that I can know what is on my MiniDV disk without putting them in each time to view in order to find what is on the reel.
    As always thank you in advance for your reply to my Post,
    Sebastian
    Bryce Whiteside replied 21 years, 5 months ago 2 Members · 1 Reply
  • Bryce Whiteside
    April 25, 2005 at 6:42 pm
    It won’t make thumbnails. So for that you need read this post, just a little ways down.
    Media Asset Management Tools and FCP HD by Totti on Apr 24, 2005 at 11:08 pm
    https://www.creativecow.net/forum/read_post.php?postid=111438770076021&forumid=8
    You can make your bin’s show or hide any number of columns for useful information when you log and capture. I always liked the way Media100 would have the reel number column first, then in, then out and then duration so I simply had a customized column layout in FCP similiar to M100. Also you can import/export column data from spreadsheets. You can sort the columns the way you want. Check you manual for customizing the Bin Layout window and your import export options which are only limited by your imagination.
    HTH,
    Bryce
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
