Activity Forums Apple Final Cut Pro Legacy does it make a difference where i capture the media?
  • does it make a difference where i capture the media?
    Posted by Alexander Gao on February 17, 2006 at 4:52 am
    I noticed that sorenson squeeze has an option to capture dv. This won’t give me any better results than getting it straight from fcp, will it?
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
    Todd Gillespie replied 20 years, 6 months ago 2 Members · 1 Reply
  • Todd Gillespie
    February 21, 2006 at 1:59 am
    Nope.
    Most DV firewire signal is using the data rate of 3.7 MByte/sec. So the quality is the same. No reason to use it unless you didn’t have FCP.
    Good Luck,
    Todd at UCSB
    Television Production
