Activity Forums AJA Video Systems Does Io have conflicts with M-Audio soundcards?
  • Does Io have conflicts with M-Audio soundcards?
    Posted by Beelaster on May 27, 2005 at 4:04 am
    I am the proud owner of a new Io (buh-bye Xpress Pro) and I was wondering as I build this system whether there are any known conflicts between the Io and any soundcards. The Avid Mojo can’t share a tower with anything.
    I know I have to monitor audio in FCP from the Io. That’s a pretty simple setting change…
    Annaël Beauchemin replied 21 years, 3 months ago 3 Members · 3 Replies
  • David Jones
    May 27, 2005 at 3:00 pm
    You can also record audio along with video using the IO.
  • Beelaster
    May 27, 2005 at 11:38 pm
    I know. What I was wondering is whether there are driver conflicts, hardware conflicts, etc.
    I am trying to divide NLE and DAW duties in the same box.
    G5 dual 2.0/2gig/sonnet allegro FW800 PCI/3X250 LaCie FW800 extreme/AJA Io/Horita BSG-50/DSR-45/DSR-11/M-Audio Delta 1010LT/JVC Hi-Res Ref Monitor/stock 5200 video card/Prod Suite/Logic 7.1/Avid Xpress Pro
  • Annaël Beauchemin
    May 31, 2005 at 3:37 pm
    The system I work on sometimes has the Io + Revolution 7.1. This is not a Delta 1010, but a M-Audio nonetheless.
    it should be fine, however you must remember to use the Io’s audio output when monitoring in FCP. Otherwise audio will not be sync to the video. The M-Audio should work fine for voice over recording, tho.
