Activity Forums Maxon Cinema 4D Does Inheritance effector work with ployfx objects?
  • Adam Trachtenberg
    July 8, 2015 at 5:33 pm
    The first problem is that you have the inheritance effector’s weight set to 0% in the falloff tab.
    The second issue is that you’re referencing a plane object, which the effector is going to interpret as a single mograph particle. You can get around that by creating a matrix object, setting it to object mode referencing the final destination plane (polygon center mode), and then use matrix object in the inheritance effector instead of the plane.
  • Paolo Rave
    July 9, 2015 at 8:46 am
    thanks a lot adam! that did the trick!
    meanwhile I would ask you another thing!
    I have a scene where I have a parametric cube, and I want it to grow on one axis … the problem is that if i set the scale of just one axis to zero, i can still see the object, and i have to scale down the other axis as well. How can I make it grow from zero on one axis?
    Is there also anyway to change the pivot from the effector?
    here’s the scene file
    https://www.dropbox.com/s/vfa1spfq4ce7jj9/Plane_scale.c4d?dl=0
  • Adam Trachtenberg
    July 9, 2015 at 3:48 pm
    You can get the object to scale from the bottom by placing it in a null aligned to the bottom of the object.
    As far as it scaling to -1, I guess it doesn’t disappear entirely because scaling to -1 on a single axis just creates a plane. You can get around it by using a little Xpresso as in the example here: 9033_planescaleamt.c4d.zip
  • Paolo Rave
    July 9, 2015 at 4:10 pm
    this is great adam! I had a look at the xpresso setup and I got little bit confused at first by looking at the result node (that was simply a demonstration of the output i was getting)… now everything is in it’s place!!
    a billion thanks adam! I hope to get seriously in xpresso really soon!
    ciao!
