Activity Forums Adobe After Effects Does importing layer sets from photoshop into After Effects slow it down alot?
  • Does importing layer sets from photoshop into After Effects slow it down alot?
    Posted by Daniel Haskett on May 12, 2005 at 1:07 am
    hi there
    Basically Im having the problem that when importing a photoshop file as a composition it is running extremely slow. The photoshop file is about 100meg so I guess that isnt a good start? The reason its so big is because I have about 20 copies of the same chair that I want to appear and then 20 copies of the same machine for the same reason…is there anyway I can do this better..it is just so ridiculously slow, i love after effects, but im going mad! 90% rendering, 10% working 🙁
    cheers
    dan
    Joe Chao replied 21 years, 4 months ago 2 Members · 1 Reply
  • Joe Chao
    May 12, 2005 at 2:20 am
    Since all these chairs are the same ,why don’t you just creat one chair and duplicate it in AE?
    Then I think maybe you should check the size of your Psd file.I meant checking the width and weighth.If you were making a Pal video and your chairs needed not to be scaled into very large size in your footage,a PSD file in720*576pix(72pix/inch) is enough.A file in too large size will not improve your work but drive you AE into grind.
    My name is always misread as COW……..:)
    so I got this ID:
    friendcao2004@hotmail.com
