Activity › Forums › Panasonic Cameras › Does HVX200 has SDI?
Posted by Hhv_pro on June 27, 2006 at 10:30 pmDoes HVX200 has SDI? IF not and you are plan to shoot > 6hrs live event in HD 720P@24 frame how would you do it?
THanks
Phil Bradshaw replied 16 years, 8 months ago 6 Members · 7 Replies -
Shane Ross
June 27, 2006 at 10:39 pmIt does not.
6 hour live event? I’d have an assistant on hand, 3-5 P2 cards and a laptop and hard drive offload station. When one card fills up, yank it, put in another one and skuttle off to offload the footage. It takes less time to offload than to record…especially at 24PN. But 4 cards would be a good backup.
My producer recorded his daughters piano recital for 1.5 hours and the all fit on the 10 P2 cards he had. And when he imported them they all matched up perfectly in the timeline…not one lost frame. I hear that the Firestore has problems with long continuous takes.
Shane
Alokut Productions
http://www.lfhd.net -
Jim Carswell
June 28, 2006 at 3:00 pmIf it’s a stationary shoot… would it be worth going directly into a laptop with an external hard drive?
JimJim Carswell
Spyhop Productions, Inc.
Savannah, GA
http://www.spyhopproductions.com -
Shane Ross
June 28, 2006 at 5:27 pmI’d avoid that. What if the drive fails? What if the capture process stops for some reason?
Plus you really cannot capture 6 hours at one time into FCP. No…this is not the way to go for many many reasons.
Shane
Alokut Productions
Lawrence Marshall
June 29, 2006 at 2:40 pmI can verify safely recording to a Mac laptop and external SATA drive (using a SATA PCMCIA card) for 2-hour blocks at a time with nary a hiccup in FCP 4.5…
Larry M
Hhv_pro
June 29, 2006 at 5:15 pmHow about Avid/PPro 2.0 on PC side? Has any one tried it?
My concern with 8gb card is if there enough free time for assistance to dump the 8 GB card before two cards on camera are filled?
Joe Murray
July 8, 2006 at 10:46 pmOffload time with my Powerbook to an external firewire drive is about 5-6 minutes for an 8 gig card. Shooting 720 pn you’ll have 20 minutes of shooting time per card. So it gives you enough time to shoot continuously.
Joe Murray
Phil Bradshaw
January 5, 2010 at 5:40 pmShane,
We use the component output on our camera to output an HD signal. Do you know if there is a cable that will transmit an SDI signal via the component jack on the camera (7 pin, snap-in)?
I’m specifically asking because I’m considering purchasing a TV Logic 7″ LCD monitor, and the Waveform and V-scope options will only work with an SDI signal.
Thanks for your time.
Phil
