[Russell Lasson] “If I shoot 720/24P on the HDX900, will my Kona card be able to remove the duplicate frames like it does with the Varicam?”
Correct Russell.
Extracting the 24/25/30/50/60 frame rates work the same way, Use the Kona easy setup for 24p
Make sure you use the Aja Kona Easy Setup 720p23.98 Varicam to handle the flags properly
“Also, I’m guessing that it doesn’t add flags to 1080/24P or 1080/24PA material. So the best way to remove those extra fields is digitizing over firewire.”
Panasonic’s version of 24p are laid to 1080 60i on the tape, (not the 24 frames on HDCAM) but works the same way, however 24pA gives better results without the mushy C frame, however you do need to extract the redundant frames over FW only.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
