Activity Forums Apple Final Cut Pro Legacy Does HD some in PAL AND NTSC flavors??
  • Does HD some in PAL AND NTSC flavors??
    Posted by Joseph Wilkins on March 11, 2008 at 10:44 pm
    I have a client in Australia who wants to air a TV spot I created here in NTSC land.
    The footage is raw DVCPROHD.
    What’s the best way to send it to them?
    They want digital quicktime format
    thanks!
    Walter Biscardi replied 18 years, 5 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    March 11, 2008 at 10:49 pm
    What frame rate to you have it in?
  • Joseph Wilkins
    March 11, 2008 at 11:22 pm
    23.98
  • Jeremy Garchow
    March 11, 2008 at 11:26 pm
    Well, then you can conform the spot to 25 using Cinema Tools. Export a self contained of the spot, duplicate that self contained via the finder, then open the dupe cinema tools and hit conform and choose 25.
    This will change the timing of your spot (it will be shorter) and your audio will be pitched up, but it will be a clean conversion with no interpolation. See if that will work for them. If not send them the 23.98 spot and they will conform however they see fit.
    Jeremy
  • Walter Biscardi
    March 11, 2008 at 11:50 pm
    In answer to your question, yes HD does come in PAL and NTSC flavors.
    1080i/60 is NTSC
    1080i/50 is PAL
    720/60 is NTSC
    720/50 is PAL so long as the camera/deck is set up for 25/50 instead of 30/60.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
