Activity › Forums › Adobe After Effects › Does having lots of inactive compositions in a project slow it down?
  • Does having lots of inactive compositions in a project slow it down?
    Posted by Daniel Haskett on May 15, 2005 at 11:07 pm
    Hi there
    Basically I was just wondering if you have lots of compositions in a project that arent being used does it slow down your work? Never sure whether to have one project with lots of compositions or lots of projects which can then all be imported into one final composition at the end….
    cheers
    dan
    Steve Roberts replied 21 years, 4 months ago 3 Members · 2 Replies
  • Yoondo
    May 16, 2005 at 12:50 am
    Inactive comps will not slow down your work flow or your rendering time.
    As far as having bunch of comps in one project, it all depends on what you want to do.
    In my opinion, if the comps are not associated with each other, you should have separate
    projects which would be better organized.
    My 2 cents.
  • Steve Roberts
    It might slow down the opening and saving of the AEP file, but not the display of the current frame or the rendering of the comp.
    Steve
