Activity Forums Apple Final Cut Pro Does FCP X Save An Output File When Sharing To Vimeo / YouTube Directly From Share Menu?
  • Does FCP X Save An Output File When Sharing To Vimeo / YouTube Directly From Share Menu?
    Posted by Tony Brittan on September 28, 2012 at 3:14 pm
    The Subject pretty much says it all. I was just curious if X actually saves an outputted file when it’s publishing directly to one of those services? Or does it share the file, then discard it? I haven’t been able to find an clear answer on that yet and can’t find a file using spotlight either.
    I’ve been using X more and more and am digging it quite a bit! I just finished a promo for a Zombie walk using it (and some After Effects as well as Crazy Talk for Mac to animate the zombie face). Here’s a link:
    https://vimeo.com/50376665
    Tony Brittan
    Island Shore Productions
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Tony Brittan replied 13 years, 7 months ago 1 Member · 1 Reply
  • Tony Brittan
    September 28, 2012 at 3:20 pm
    I actually just answered my own question! I found it in Final Cut Projects > (project name) > (version name folder) > Shared Items
    In case any of you were wondering…I guess my machine was indexing the drive after two system freezes / re-starts caused by FCP X and this project. Yea, that did suck. But it DID come right back to where I was with everything intact.
