Activity › Forums › Apple Final Cut Pro Legacy › Does FCP have “easy-ease” keyframe capability?
Devrim Akteke replied 1 year, 9 months ago 8 Members · 12 Replies
Kristina Atanasova
November 23, 2024 at 8:46 pmI know this discussion is quite old, but since the topic is still very relevant and many users face similar challenges even with FCP 11, I wanted to share a solution that might help others looking for an answer.
There’s a plugin called EasyEase, which addresses this exact issue. It allows you to apply custom easing functions to the Position, Rotation, and Scale parameters of an element directly in Final Cut Pro. The key difference compared to plugins like AddMotion is that EasyEase works with actual keyframed animations, offering full control over the movement between keyframes. This means you’re not restricted to a simple A-to-B movement—it lets you create much more organic and fluid animations.
If anyone here has been looking for a way to achieve smooth, professional keyframe easing in FCP, this plugin might be worth checking out!
fxfactory.com
Custom easing functions for position, scale, and rotation of your clips. Plugins and effects for Final Cut Pro.
Devrim Akteke
November 24, 2024 at 4:49 amIt’s great news. It is a shame FCP is very bad at this keyframing issue. I will give it a go as soon as I can.
