Activity Forums Apple Final Cut Pro Legacy Does FCP convert just as good as Compressor
  • Does FCP convert just as good as Compressor
    Posted by Phil Muri on November 8, 2009 at 11:59 pm
    Howdy Cowpokes,
    I’m having some issues with Compressor 3.5.1 not doing what it is supposed to… So my question is…
    If I drop a movie into an FCP timeline with my desired output settings… will FCP export the movie just as well as if I were to convert in Compressor? I am using XDCAM HD422 1080p30 (50Mb/s) footage and wish to output into Apple ProRes422HQ (for interlaced material).
    Here is my original post (https://forums.creativecow.net/thread/8/1061548)
    -Phil
    John Fishback replied 16 years, 10 months ago 4 Members · 3 Replies
  • Jakob Mårtensson
    November 9, 2009 at 1:43 am
    I have personally not seen any difference between the two when using intermediate codecs, only when compressing for the web or DVD, but then again if the result was exactly the same they hadn’t made compressor in the first place 😉
  • Walter Biscardi
    November 9, 2009 at 11:50 am
    First, no reason to start two threads for the same topic.
    Second, FCP and Compressor both use the exact same compression engine.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • John Fishback
    November 10, 2009 at 3:44 pm
    I thought Compressor did a much better job scaling when using Frame Controls compared to FCP. In this case there shouldn’t be a change in scale, so that probably doesn’t matter. But what are your thoughts on scaling, Walter?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
