Activity › Forums › Apple Final Cut Pro Legacy › Does FCP 6.0.2 supports 59.94 drop frame ?
  • Shane Ross
    November 27, 2007 at 3:38 am
    FCP 6.0.2 now has support for 720p 59.94 drop frame timelines.
    And I gave you a workaround on your other question.
    Shane
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Mark Maness
    November 27, 2007 at 5:04 pm
    Yes.
    And just for frame of reference next time… When you refer to 59.94, that is drop frame. If it were non-drop, it would be 60.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Gary Adcock
    November 27, 2007 at 9:44 pm
    [Wayne Carey] “And just for frame of reference next time… When you refer to 59.94, that is drop frame. If it were non-drop, it would be 60.”
    Nope…
    We do not work with round integer numbers in NTSC land
    while 59.94 is drop frame in 1080i
    it can be both Drop and Non Drop in 720p….
    the history with Progressive formats is they are usually non drop, interlace is always played out as DF.
    23.98 is non drop- the recording method is physically slowed down to match the DF timing for a direct conversion to NTSC for viewing and playback.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
