Activity Forums VEGAS Pro Does disable resample assist or hinder a velocity envelope?
  • Does disable resample assist or hinder a velocity envelope?
    Posted by Phil Loarie on August 29, 2011 at 6:03 pm
    Hello,
    I have a project where I am doing a velocity envelope in the tail shot from 300% down to zero (freeze frame) and noticed that as it approaches zero there is a bit of a stutter. I have checked disable resample in this clip’s properties should I enable smart sample instead? (The clip is very short, less than 12 seconds.)
    Thanks in advance,
    -Phil
    Phil Loarie replied 15 years ago 2 Members · 2 Replies
  • John Rofrano
    August 29, 2011 at 8:40 pm
    [Phil Loarie] “should I enable smart sample instead? “
    Yes, the stutter is caused by not resampling the frames. Smart sample will synthesize new frames to try and make the motion smoother.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Phil Loarie
    August 29, 2011 at 10:17 pm
    Hello John,
    Thank you for your help. I will try this out tonight.
    -Phil
