Activity Forums Adobe After Effects Does different light temperature effect chroma keying?
  • Does different light temperature effect chroma keying?
    Posted by Travis Wine on November 29, 2011 at 3:19 pm
    I want to use three point lighting for the subject at 3200k, but I will be using 5500k for the green screen, so theoretically it still should key out fine as long as the green is a constant temperature without spill from the 3-point lighting – right?
    I just don’t have the 3200k light set up for green screen yet.
    Any thoughts?
    Tudor “ted” jelescu replied 14 years, 9 months ago 3 Members · 4 Replies
  • Ben G unguren
    November 29, 2011 at 6:06 pm
    For questions like these, a test run is ideal. Unless I’m thinking this through incorrectly, if you’re balancing for tungsten, this will push your daylight-color on the greenscreen into blue. I’d think you’re okay, as blue doesn’t conflict much with skin tones, either (assuming wardrobe isn’t going to conflict). I’d be a lot more concerned if I were doing it the other way around (subject with daylight, background with tungsten).
    Why not grab some blue gel and up the color temperature on your subject? That’s a pretty inexpensive solution, and takes out this uncertainty….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Tudor “ted” jelescu
    November 29, 2011 at 7:27 pm
    I agree with Ben – a test is always good and most times a budget or sanity saver. In principle you should be ok, but the filter solution may prove better, only I would try warm filters on the 5500k lights.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Travis Wine
    November 29, 2011 at 7:42 pm
    Thanks for the responses folks.
    I just saw where Sears has flood lights on sale cheap. They run 3200k. I just need to set these far enough away so they don’t overpower the green screen.
    However, I will experiment day of shoot after filming and post back results for those interested. I am.
    I will be shooting with my Sony NXCAM – it has a built in 10 bit 4.2.2 uncompressed HD- SDI connector. I will be using this output to capture to my BlackMagic HyperDeck Shuttle. Yeah – Had to mention that. I’m excited to see results for 1st time.
    Thanks Again!
    November 30, 2011 at 8:07 am
    I would be interested to hear about the results- let us know how it went.
    Tudor “Ted” Jelescu
    Senior VFX Artist
