Activity Forums DaVinci Resolve Does Davinci resolve capture prores in windows os?
  • Does Davinci resolve capture prores in windows os?
    Posted by Ricardo Marty on June 15, 2018 at 10:27 pm
    I kinda read when dr12.5 came out that the windows version could capture prores but could not output prores.
    Is this true for version 15?
    Ricardo Marty
    Michael Gissing replied 8 years, 2 months ago 7 Members · 16 Replies
  • 16 Replies
  • Shane Ross
    June 15, 2018 at 11:48 pm
    Capturing from tape to ProRes would mean having the ability to ENCODE to ProRes, and Windows machines don’t have the ability to encode to ProRes. No matter what version of Resolve you have, this is true.
    Well, you CAN encode to ProRes, with some third party apps, but they aren’t licensed to do so, and the encoder doesn’t quite encode ProRes properly. If QC looks at it, it’ll kick it. But these apps won’t aid Resolve in capturing and encoding to ProRes.
    Total stinker, as many many clients want ProRes, and that means double encoding on a Windows system.
    Shane
    Little Frog Post
  • Marc Wielage
    June 16, 2018 at 5:21 am
    Note this is due to decisions made by Apple, so it has nothing to do with Blackmagic or Resolve users per se. One solution is just to buy an affordable Mac (like an iMac Pro) and let that be a ProRes render station. Even some used Macs could do it to a point. The Advanced Linux version can do it ($30K).
  • Duke Sweden
    June 16, 2018 at 12:15 pm
    Is DNxHD or DNxHR just as good as ProRes, other than in the minds of people who don’t know what they’re talking about, or is ProRes that much better? I ask, of course, as the amateur that I always point out that I am.
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    DaVinci Resolve 14.3
  • Tero Ahlfors
    June 16, 2018 at 2:08 pm
    [Duke Sweden] “Is DNxHD or DNxHR just as good as ProRes”
    Yes, but there are clients/services that require Prores for delivery so you will need some way to make those files. If you’re doing stuff just for your own fun then it doesn’t really matter.
  • Ricardo Marty
    June 16, 2018 at 2:55 pm
    My situation is that I plan to purchase the new bmpcc 4k abd these are the codecs:
    CinemaDNG RAW, CinemaDNG RAW 3:1, CinemaDNG RAW 4:1, ProRes 422 HQ QuickTime, ProRes 422 QuickTime, ProRes 422 LT QuickTime, ProRes 422 Proxy QuickTime.
    Though my system specs can handle some raw I would rather work in something else.
    Ricardo Marty
  • Duke Sweden
    June 16, 2018 at 3:03 pm
    Thanks, Tero. As I said I was just asking out of curiosity since, as you pointed out, I do this for fun and delivery codecs aren’t important to me.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Duke Sweden
    June 16, 2018 at 3:08 pm
    Hey Shane. Back when I had an Atomos Ninja II (which I used with a Nikon D5500. Can you believe that!?! ;-)) Anyway, I was able to record in ProRes 4:4:4 and work with those files on my old, woefully underpowered PC. I just couldn’t export in ProRes. Is that what you meant?
    btw, I did find a program called something like Mirabel ProRes for Windows, which as you point out, was nothing like real ProRes.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Tero Ahlfors
    June 16, 2018 at 3:45 pm
    You can import Prores so you can shoot with a camera that records Prores and bring those files in and work with that. You can’t export your work out to Prores and you’ll need to use something else.
  • Ricardo Marty
    June 16, 2018 at 7:02 pm
    OK you meab I can graf a prores clip into my windows davinci project and work with it then expoRt as whateve.
    Ricardo Marty
  • Tero Ahlfors
    June 16, 2018 at 7:08 pm
    Yes
