Activity › Forums › Apple Final Cut Pro Legacy › Does Compressor Mux?
  • Does Compressor Mux?
    Posted by Scot Walker on July 8, 2005 at 4:15 pm
    I think I’m using the correct terminology here…
    I need to output a QT movie that uses the MPEG2 codec but also has the audio included in the QT movie, not separate.
    All of the presets I see in Compressor output the audio separate from the video.
    Any help would be greatly appreciated.
    Neil Sadwelkar replied 21 years, 2 months ago 3 Members · 11 Replies
  • 11 Replies
  • Chris Poisson
    July 8, 2005 at 5:17 pm
    Scott,
    I don’t think it does natively, but I’m pretty sure you can create a preset that would do this. There was aa big disscussion on adding presets a couple of months ago.
  • Scot Walker
    July 8, 2005 at 5:24 pm
    Thanks for the response.
    Do you have any idea what I would be looking for in the Compressor custom settings? The only place I see anything about audio in the MPEG2 dialog is in the Extras tab – “Multiplexed MPEG-1/Layer 2 Audio: Select this to create an MPEG-2 Transport stream with multiplexed audio.”
    Any other ideas or alternative software that does it?
    Thank you
  • Chris Poisson
    July 8, 2005 at 6:23 pm
    Hey Scott,
    I saw that tab also, but I just tried it and QT can’t open the resulting file.
    Cleaner will do a muxed file, as will Compression Master 3 and Squeeze Suite 4.1.
  • Scot Walker
    July 8, 2005 at 6:31 pm
    OK, thank you!
    Do you use the Animation codec to take projects to those applications?
  • Chris Poisson
    July 8, 2005 at 7:08 pm
    Sure, you can’t go wrong with Animation, but I also use uncompressed 8 bit, as that’s what I mostly work in.
  • Scot Walker
    July 8, 2005 at 7:09 pm
    Great. Thanks for all the info!
  • Chris Poisson
    July 8, 2005 at 7:14 pm
    Say,
    I’m just curious, what do you need a muxed mpeg for, playing from a server?
  • Scot Walker
    July 8, 2005 at 7:15 pm
    No, to play from a Windows PC’s hard drive. MPEG2 plays in WMP.
  • Chris Poisson
    July 8, 2005 at 11:13 pm
    Scot,
    You could also look into Popwire’s WMV component or Flip4Mac which are much cheaper than the other programs I mentioned.
  • Scot Walker
    July 9, 2005 at 4:06 pm
    Yes, I definitely need to get one of those and go out WMV9 at some point. I’ve never heard of Popwire. Thanks for the tip!
