Activity › Forums › Apple Final Cut Pro Legacy › Does compressor have trouble with crossfades?
Posted by Michael Allen on October 9, 2006 at 4:01 pmCrossfades look good in timeline but bad after compressor. Not all crossfades are bad but many are a little pixelated for lack of a better term. Using best quality 90 min. setting preset.
Mike
Jeremy Garchow replied 19 years, 12 months ago 7 Members · 7 Replies -
David Roth weiss
October 9, 2006 at 4:37 pmMike,
I also noticed this issue in the latest Compressor update. I think its a 2-pass VBR thing. I’m doing another pass today and will switch the preset to CBR. You might want to try that too.
DRW
Jeff Carpenter
October 9, 2006 at 5:24 pmHow are you exporting? Are you using EXPORT>COMPRESSOR right in Final Cut or are you exporting a Quicktime file and dragging that into Compressor?
Try that first option if you’re not already.
Don Greening
October 9, 2006 at 5:53 pm[David Roth Weiss] “I also noticed this issue in the latest Compressor update.”
I thought that the broken VBR thing was supposed to be fixed in v.2.1. I know that Compressor 2.0 has problems with the VBR setting, resulting in pixelated cross dissolves and fades. That’s why I bought Bitvice when I need to encode with VBR. FWIW, the CBR results in both Compressor and Bitvice look pretty much the same, with Compressor working quite a bit faster.
– Don
“Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
David Roth weiss
October 9, 2006 at 6:09 pmJeff,
Actually, I noticed this issue after I encoded right from the timeline. So, what does that tell you??? It seems to me Apple may well have taken one step forward and then five steps back…
DRW
Chris Babbitt
October 9, 2006 at 6:44 pmThat’s correct. I’ve had no issues with 2-Pass since the upgrade. It must be something else.
Dan Riley
October 9, 2006 at 8:31 pmWhat I did, and I did this back in compressor 1.5 is
go into the encode area (in the preset you use) then to GOP
and set this (group of pictures) to low, like 7.
What this does is compress on a less number of
frames at a time for a much better result.
This is typically done when compression artists customize a
compression job. So you lose some space this way
since you are doing it for the entire encode.
All this does is increase the file size a bit.
This is not a problem if your show is 30 or 60 minutes.
and not an issue at all a 1 or 2 minute sequences.Try it to see what you think.
Dan -
Jeremy Garchow
October 9, 2006 at 11:09 pmI have done multiple 2 pass VBR encodes (after the 5.1.2 update) and all is well. My method is to render everything (including full rt effects) and then export a reference movie and drop that into compressor.
Jeremy
