Activity Forums Adobe After Effects Does COLLECT FILES copy or move source material?
  • Does COLLECT FILES copy or move source material?
    Posted by Ty Frey on September 18, 2009 at 10:59 pm
    Have a huge AE (CS3) project with 20+ comps, most were carried over from FCP using Autoduck.
    I’d like to COPY the entire AE project to another drive, to render on another machine while I continue to work. If I use the “collect files” command, will it move my original source files (I don’t want this), or will it copy them to the new location (I DO want this)?
    I’d like to keep the source material undisturbed in its organizational glory. I don’t suppose this action is undo-able so I wanted to ask first. The help file seemed unclear on this issue, or maybe I have poor reading comprehension.
    Thank you!
    Ty
    Ty Frey replied 16 years, 11 months ago 4 Members · 4 Replies
  • Alexandre Braso
    September 18, 2009 at 11:33 pm
    The collect files will do exactly that you want, copy your files and don´t touch your original files.
    be atention to your project folders organization, the copy of your project will follow de organization of the project and not the organization of your original files.
    Alexandre Braso
    http://www.pixelsrender.com.br
  • Kevin Camp
    September 18, 2009 at 11:58 pm
    hi ty,
    it will copy material to the new location.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Todd Kopriva
    September 19, 2009 at 12:11 am
    What part of the Help document is unclear? I’d be happy to fix it. Here are the first two paragraphs from the page about Collect Files:
    “The Collect Files command gathers copies of all of the files in a project or composition into a single location. Using this command is a useful step before rendering, for archiving, or for moving a project to a different computer system or user account.
    When you use the Collect Files command, After Effects creates a new folder in which it saves a new copy of the project, copies of the footage files, proxy files as specified, and a report describing the files, effects, and fonts necessary to re-create the project and render the compositions.”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Ty Frey
    September 19, 2009 at 1:14 am
    Perfect! Thanks everyone!
