Activity Forums Blackmagic Design Does Blackmagic capture 1080 25p or 1080 25psf?
  • Does Blackmagic capture 1080 25p or 1080 25psf?
    Posted by Marcus Ionis on August 2, 2006 at 5:14 am
    I have a project coming my way, were the client wants 1080 25p or 1080 25psf. They can’t work in 1080 50i because of interlaced artifacts. Does Blackmagic capture this frequency and does it work? Does it capture in it’s own Blackmagic codec or does it allow you to capture in the Uncompress FCP 10-bit codec?
    Thank You
    Marcus
    Nico Sandhof replied 20 years, 1 month ago 3 Members · 3 Replies
  • Kristian Lam
    August 2, 2006 at 6:07 am
    Hi Marcus,
    We use 25PsF and capture to the Uncompressed FCP 10-bit codec.
    You’ll use the 1080i50 setup in Final Cut Pro that we provide, but set the field dominance to NONE in the sequence settings.
    regards
    Kristian Lam
    Blackmagic Design
  • Marcus Ionis
    August 2, 2006 at 3:24 pm
    What about the file that is captured? If the tape is 25psf and the digitizer is set of 50i.
    Does this add any interlace artifacts?
    Thank You for Your Time & Patience
    Marcus
  • Nico Sandhof
    August 2, 2006 at 7:33 pm
    psf – progressiv segmented frame – a real progressiv frame in 50i…
