Activity › Forums › Avid Media Composer › Does Avid have an on air insertion feature in the line?
  • Does Avid have an on air insertion feature in the line?
    Posted by Jerry Hofmann on May 13, 2005 at 3:16 am
    I have a client with the need for this. Insertion of graphics only for on air application. Does Avid have a solution for this? has to capture and go out inserting on the fly just like on air hardware (swicher inserting from CG). Product would also have to edit I suppose as well.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
    Shane Ross replied 21 years, 4 months ago 2 Members · 1 Reply
  • Shane Ross
    May 13, 2005 at 6:06 pm
    I don’t believe so. And Avid is an NLE, not a switcher. You can’t have video go in and out at the same time. You’d have to digitize the entire show, add the bug, then output. Not the best solution seeing that you’d be losing quality by capturing and output.
