Activity Forums Avid Media Composer Does Avid always import audio levels exactly as they are?
  • Does Avid always import audio levels exactly as they are?
    Posted by Juan Juig on February 20, 2020 at 12:02 pm
    Does Avid always preserve the values of audio levels exactly as they are?
    I never had any problems when doing the final exports, but it would be nice to have a definite confirmation that when I import the audio file that was mixed correctly to broadcast standards in another software, it will remain exactly the same (in terms of audio levels) and still suitable for any TV station.
    Is that the case or are there any important settings in Avid that need to be changed?
    Job Ter burg replied 6 years, 7 months ago 4 Members · 3 Replies
  • Shane Ross
    February 20, 2020 at 10:41 pm
    Yes, they come in at the level they were mixed, and are not raised or lowered. This is true of ALL imported audio.
    Shane
    Little Frog Post
  • Glenn Sakatch
    February 21, 2020 at 7:55 pm
    There used to be an import setting that would drop the audio level of music..I think imported if cd ..by an amount you could specify.
    Not sure if it is still kicking around anywhere.
    But certainly for the sake of a typical workflow, it just brings it in
    clean
    Glenn
  • Job Ter burg
    February 23, 2020 at 6:19 pm
    Beware that pannings are set correct, though (if you import as monophonic).
