Activity › Forums › Field Production › Does anyone recognize this flicker in the original file?
  • Does anyone recognize this flicker in the original file?
    Posted by Kell Smith on March 24, 2017 at 8:39 pm
    I’m trying to figure out 1) what this is 2) how to remove it from the edit 3) how to avoid it in the future.
    It’s AVCHD, 1080p5997. The vertical frame on the window is flickering. Upon slowing it down, I see that these four frames repeat (attached). Also, example is attached.
    This is in the original MTS file viewed in VLC, as well as in the editor. Attempts at flicker removal, either from the motion panel in Premiere or the field options right-clicking the timeline, make it worse, as does any transcode, particularly to mpeg2 for DVD.
    Does this by chance look familiar to anyone?
    Thank you
    Here is an example 11172_flickeroff2.mp4.zip
    Kell Smith replied 9 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
