Activity › Forums › Adobe Premiere Pro › Does anyone know how to create a shortcut similar to After Effects Set To In Point default is: [{ to set in point or ]} to Set Out Point
  • Does anyone know how to create a shortcut similar to After Effects Set To In Point default is: [{ to set in point or ]} to Set Out Point
    Posted by Fernando Acevedo on April 6, 2017 at 5:36 pm
    Please note this is not the typical MARK IN or MARK OUT which default shortcuts are I & O.
    Can this be reproduced in Premiere Pro where I could set a shortcut on my keyboard that will
    move my clips In Point or Out Point to where the Play Head or (Current Time Indicator for AE users) is located
    In other words, regardless of where the clip is on the time-line in relation to the Play Head, with the press of a shortcut I can move the clip
    head or end to where the Play Head is parked in the time-line.
    Thanks in advance!
    Fernando Acevedo
    HASTA LA BYE BYE!
    Fernando Acevedo replied 9 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
