Activity › Forums › Adobe After Effects › Does anyone have any tips on how to animate turnstiles moving around?
  • Does anyone have any tips on how to animate turnstiles moving around?
    Posted by Daniel Haskett on May 1, 2005 at 5:23 pm
    Hi there
    Basically I have drawn a picture of some turnstiles similar to those in this photo – https://www.kaba.co.uk/is/images/products/turnstiles.jpg
    I want it to look like they are moving around but I really dont know where to start, does anyone have any tips? Would I need to do each section as a separate drawing/layer and then animate separately in 3d mode?
    Thanks in advance!
    Dan
    Tom Daigon replied 21 years, 5 months ago 4 Members · 3 Replies
  • Glenn Moore
    May 1, 2005 at 6:15 pm
    I’ll take a shot at this 🙂
    You can create one set of the turnstyle arms (say, North and South or along the x-axis). Duplicate it and in 3D mode make them perpediclular as they are in real-life.
    To animate them, parent one to the other and then parent the parent to a Null objet. You would then only have to rotate the Null along the Y-axis.
    Someone may have an easier or better explanation but If you’re not doing it in a 3D app, that’s the way I’d go.
  • Steve Roberts
    May 1, 2005 at 6:46 pm
    Maybe Trapcode’s 3D Stroke?
    Steve
  • Tom Daigon
    May 1, 2005 at 8:39 pm
    How about drawing them from the top view in Illustrator, then import into 3D Invigorator and extrude for a true 3d object that can be rotated.
