Activity Forums Adobe After Effects Does anyone have any tips on how to animate a WRITE-ON effect on this drawing?
  • Does anyone have any tips on how to animate a WRITE-ON effect on this drawing?
    Posted by Daniel Haskett on May 7, 2005 at 7:57 pm
    Hi there
    Basically I have a drawing which you can see here https://pg.photos.yahoo.com/ph/dangerass2000/album?.dir=5b6b called Pier-For-Web,I know the quality isnt great, I dont know how to make it better in yahoo. But basically I want to have the slide on the pier wind down and reveal itself, and the dome form itself from the ground, but Im not sure of the best way to do this. I tried doing an open mask and then render stroke and reveal original image, but you can only do it once Ive found…or if you do it again on a new mask, it wont reveal more? Is it possible to make brush strokes reveal the image? Any help would be greatly appreciated!
    Also if you look at the image sea for web, its a print Ive done that Id like to animate, give the impression of the sea moving but Im not sure of the best way, if anyone has any tips on how it could be done Id really appreciate that!
    Thanks in advance!
    Dan
    Filip Vandueren replied 21 years, 3 months ago 2 Members · 3 Replies
  • Filip Vandueren
    May 8, 2005 at 9:54 pm
    I think it would be handier to expand the pier-image to a few different layers in photoshop, that you can mask-animate one by one, just animating the masks; or adding some wipes might be all you need.
    But by breaking it up in smaller portions, you’ll save yourself the headache of oddly-shaped masks.
    As for the image of the sea, take a look at the combination caustics + wave world, it may be all you need. I’m sure there are plenty of tutorials around for that stuff.
    Or, for something a bit closer to your look try this:
    • create a solid with fractal noise (low detail)
    • Add a posterize filter (7 levels is ok)
    • add a Find-Edges filter, tick eth invert box
    • now animate the evolution and maybe sub-offset of the fractal noise
    animated noise with posterize and findedges
    That gives you the lines you have, add them to anoother bluish fractal noise and tweak untill it comes close to your still-design.
  • Daniel Haskett
    May 8, 2005 at 11:48 pm
    Cool man, thanks for the reply that was really helpful!
    I was just wondering about adding the blueish fractal noise layer to it…how do I do that? sorry for sounding stupid, I tried making a new blue solid and adding fractal noise but I dont think that worked…
    Thanks for any extra help!
    Dan
  • Filip Vandueren
    May 8, 2005 at 11:58 pm
    Hi Dan,
    you can use the “mode”-setting in the fractal noise layer and set it for instance to “hard-light” or “overlay”, to combine the grey noise with the blue of your solid,
    or if you keep it to normal you can remap the greyscale noise using a “tint” (simple)or “colorama filter” after the noise.
    (fex. try the carribean preset under Ouput Cycle Presets).
