Activity Forums VEGAS Pro Does anyone edit videos over a remote desktop connection?
  • Does anyone edit videos over a remote desktop connection?
    Posted by Dar Tamayo on December 1, 2008 at 7:38 pm
    I’ve been doing all my video editing work on a dual core laptop on the couch in the living room. It works fairly good since I’m just using DV footage. I really want to get a quad core machine to help with build dynamic previews and render times, but can’t afford a quad laptop. I was thinking of getting a quadcore desktop I can setup behind the couch in a corner. I don’t want to setup a new monitor, keyboard and mouse in the living room. There isn’t room for that. I’d like to use remote desktop but I’m afraid that it won’t be fast enough for screen refreshes. I wouldn’t mind running gigabit ethernet. I just want to make sure I can get full color and clear sound. Is anyone doing this or can recommend an alternative? Maybe VNC? Or another application?
    Jake June replied 11 months, 2 weeks ago 6 Members · 7 Replies
  • 7 Replies
  • Douglas Spotted eagle
    December 1, 2008 at 9:34 pm
    I do this fairly regularly with skydiving event videos. Someone shoots and Xfers/captures the vid for me, and I’ll remotely access the vid machine at the dropzone.
    There are several methods, gotomypc.com is a good method, as is a dedicated VNC system.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Dar Tamayo
    December 1, 2008 at 10:13 pm
    So you do get full speed video and sound? No delays? Are you using 100mbit or 1gbit for your network.
    December 1, 2008 at 10:19 pm
    No delays, because it’s a remote PC. We’re not using the CPU cycles on the client machine, only on the host machine. We don’t pull the media from the host machine, it only resides on the host. The client side is merely a remote terminal. you couldn’t do serious color correcting or anything like that remotely, but the cutting…uses very little power.
    VASST
  • Danny Hays
    December 2, 2008 at 3:37 am
    I have edited in Vegas with Go to my PC before. It allows you to hear the audio from the computer your controlling. I use VNC for PC control as it’s free but there’s no audio. Also the preview refresh rate isn’t the same as if you were in front of the controlled computer, but it’s usable. At least it was for me.
    I don’t have a static IP address so for free without audio PC control, Logmein is what I use. It’s like “go to my PC” where each time your IP address changes, it let’s a server know the new address so you can still see your PC without a static IP address. But in your case at home and not over the internet, with gigabit and remote desktop, you should be able to get better results than I did. I haven’t used remote desktop but I heard you do hear the audio from the controlled computer.
    Danny Hays
  • Fotis Vassis
    December 2, 2008 at 2:38 pm
    In your workstation, allow remote desktop, assign password to your winxp, if you want access from outside of your home, port forward port 3389 to your workstation’s (internal) IP (if you have broadband router) and set an account for dyndns (use router’s builtin client or else Winxp software client)
    Start–>Programs–>Accesories–>Communication–>Remote desktop:dartamayo.dyndns.org (if outside your home) or 192.168.x.xxx (your workstation’s internal lan ip)
    That’s all you have to do from your laptop.
    All done for free
    Interchefs Culinary Club
    The Interactive Gourmet Experience
  • Chris Haywood
    May 8, 2011 at 2:19 am
    I do! But I dont believe I get 30fps. I get sharp video, I get sound, and I have to slow down the play back to be sure audio and video are aligned, because at full speed, there seems to be a slight misalignment.. I think a good idea, if you are looking for a super computer, like the other guy that has the server and the 7000 dollar set up, it buy a used server for maybe about 500.00 or less.. I did. I use an hp proliant ml570 g3 with 4 dual core 2.66ghz processors and scsi raid 5. sounded like a jet taking off when I first powered it on, I actually took a step back, wow that was fun. I use windows server 2008 R1, so I need to work on that a little bit. I dont know exactly how the other guy configured the application role of the server.. I did try it, and set it up as an application server, but when I use remote desktop, I dont know which way is better. But there does seem to be some misalignment when at full speed. Its irritating, but for now, I dont know exactly what to do to fix that problem.. I dont think a new video board will do it, but Im not sure.. still checking.
  • Jake June
    September 4, 2025 at 10:52 am
    This is an old question, but it became relevant to me recently. I started working remotely and tried several remote access options. I ended up using https://www.helpwire.app/ The connection is stable and doesn’t drop during work. I also like that it’s easy to use, works across different operating systems, and it’s free with no time limits. Hopefully my tip helps someone!
