Activity › Forums › Creative Community Conversations › does any video editing software have feature to add in/out transition effects all all medias it once ?
  • does any video editing software have feature to add in/out transition effects all all medias it once ?
    Posted by Kevin John on August 3, 2020 at 7:40 am
    Hi Guys,
    This is my first post here, forgive me if i posted in a wrong section or if my question is a silly one.
    I create videos by joining images .Currently i am using kinemaster where i add a background, then add all the images as layers and give them in and out animations (fade) to make the transition smoother. But since i use 40,50 images adding this fade in animation to all the images is a very time consuming task.
    Do we have any video editing software that enables to make to add such transition effects all or multiple images/videos easily instead of doing it 40,50 times ??..
    Neil Goodman replied 6 years, 1 month ago 5 Members · 6 Replies
  • Steve Connor
    August 3, 2020 at 9:03 am
    In FCPX you can select all the clips you want to add a fade transition to and just press “Apple-T” to apply the fade to all the clips at once
  • Kevin John
    August 3, 2020 at 9:26 am
    Hi Steve,
    Thanks for the quick reply.
    I am using windows only. Do you know any video editor that run on windows OS ?
  • Steve Connor
    August 3, 2020 at 10:42 am
    Adobe Premiere Pro or Premier Elements will do the same thing I think
  • Herb Sevush
    August 3, 2020 at 12:00 pm
    Adobe Premiere Pro will.
    You can pick any transition and make it the “Default transition.” You can then define a default length that will be used whenever applied. Then select the clips you want to apply to, hit Shift-D and it’s done. Works for audio transitions as well.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
  • Mark Suszko
    August 3, 2020 at 8:33 pm
    I’m curious about what you’re doing – it sounds like you’re doing stop-motion animation. Is that the case? Adding dissolves is kind of a round-about way to do it. We can probably com up with a better workflow for you that is more efficient and fast and gets you the look you need.
  • Neil Goodman
    August 4, 2020 at 1:07 am
    Avid. Make an in and out – select all tracks with media – transition and then check the box that says apply to everything within in an out.
