Activity Forums Adobe After Effects Does AFX still render layers out of view?
  • Does AFX still render layers out of view?
    Posted by April Henderson on March 28, 2008 at 5:33 am
    I was just wondering, does AFX render layers which aren’t visible within the comp window? For example objects that are positioned out of the view of the camera? Are they still rendered and hoggin up valuable RAM space?
    Jacob Wessler replied 18 years, 5 months ago 3 Members · 2 Replies
  • Mohammed Ovais
    March 28, 2008 at 12:30 pm
    From what I’ve just seen myself, by default it doesn’t.
    I made a comp of length 10 seconds, adding layers to that length, but I only need 2 seconds, later I adjusted the comp settings to 2 seconds. So all the layers were still at 10 seconds, with all their effects to that length as well.
    Ony 2 seconds were rendered.
  • Jacob Wessler
    March 28, 2008 at 1:38 pm
    April,
    AE will only render what is visible in the composition window. HOWEVER, it does need to keep track of other objects off-screen (so it knows where they are and if they need to appear in your video). This will start to eat into your render time, especially if you get very large, complex 3D scenes with a lot of objects in them.
    In my experience, I clip layers that aren’t visible and that seems to help with render times. Once a layer is out of view (or off screen), I trim the out point to the last visible frame. This tells AE that it doesn’t have to worry about that layer anymore. Of course, the problem comes when your objects appear and disappear from the screen. You can’t set multiple in/out points along one layer. You could duplicate the layer, but that may be causing more work than you need.
    Hope that helps a little,
    Jacob
