Activity › Forums › Adobe After Effects › does after effect create an temporary file when it crash
Posted by Hanzel Lianto on September 15, 2009 at 4:07 amHi, i was working with my after effect the whole day and it crash in the middle but unfortunately that i didn’t save my work….. i was hoping to get it back from the temporary file but just want to ask if after effect create a temporary file so hopefully i can get it back
Anyway thanks for reading this problem that i have and just give suggestion what should i do 🙂
Todd Kopriva replied 15 years, 1 month ago 4 Members · 5 Replies -
Todd Kopriva
September 15, 2009 at 11:29 amIf you have Auto-Save turned on, then After Effects saves files as you work.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Hanzel Lianto
September 15, 2009 at 11:40 amthanks for the reply……well i guess i have to do it all over anyway but is big help i think i should use auto save while i am working
Curious Turtle
September 15, 2009 at 7:41 pmAnd use the most important keyboard shortcut in the entire application often:
(Win) Ctrl-S
(Mac) Cmd-SAnd just as useful, is to use the Increment & Save feature when you’ve reached a mini-goal in your project. If your project file then gets corrupted, you can still go back to your previous major step.
It sucks, but you won’t be forgetting to save again. :o)
Good luck with your project,
BenCurious Turtle Pro Video
Training | Editing | Support
Out Now – Film Wash Color Effects Vol. 3
for After Effects & Apple Color -
Aza Allen
August 13, 2011 at 3:36 amDoesn’t auto-save do the exact same thing as increment and save? It creates a separate version in a different folder?
I only ask because Increment and Save breaks my Premiere Links…
Make sure to check out our website http://www.makeyourfriendsuncomfortable.com and my personal website http://www.ruesterprod.com
Todd Kopriva
August 14, 2011 at 7:43 pm> Doesn’t auto-save do the exact same thing as increment and save?
No.
Increment and save is for saving various versions, perhaps perpetually. Auto-save is for preventing lost work for a relatively short period.
If you have Auto-save turned on and set to save every 20 minutes and store five versions, then after two hours of working, the auto-saved version that you worked on two hours ago is gone.
If you increment and save, those versions stick around forever (until you manually delete them).
Increment and save is useful for saving at specific milestones. Some people also use it as a manual replacement for auto-save.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
