Activity Forums Apple Final Cut Pro Legacy Does adding a flicker filter de-interlace my footage?
  • Does adding a flicker filter de-interlace my footage?
    Posted by Eoin Ryan on December 17, 2008 at 10:51 pm
    Shooting PAL 50i 16:9 with Canon XL2. I use flicker filter a lot on clips that I slow down to 50% and then render. Does using the flicker filter de-interlace the footage, creating just one ‘progressive’ field?
    David Roth weiss replied 17 years, 9 months ago 3 Members · 3 Replies
  • Dennis Leppell
    December 18, 2008 at 3:37 pm
    I’m not positive that it does, but I believe the flicker filter in FCP 5.04 had de-interlace in the drop down menu as the last setting in the list, so I was always under the assumption that depending on the strength filter you were applying, you were getting varying degrees of De-interlace, which made no sense since I’d apply the flicker filter to problematic text/pics that shouldn’t have been interlaced in the first place.
  • Eoin Ryan
    December 19, 2008 at 3:25 am
    I’ve just been checking this out with some footage and there’s no doubt that you lose resolution (very noticeable).
  • David Roth weiss
    December 19, 2008 at 4:32 am
    No, it does not deinterlace the footage, it adds a blur.
    Even better is a Directional Blur set at 0 or 180 degrees and a value of 1 or 2. A directional blur will not defocus the entire image nearly as much as a gaussian blur, but minimizes the vertical flickering very much the same. That equals better in my book…
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
