Activity Forums Adobe Premiere Pro Does a nested sequence keep its render?
  • Does a nested sequence keep its render?
    Posted by Joseph Tese on April 23, 2015 at 1:45 am
    I have a nested sequence within my Main Sequence.
    Within the nested sequence is Adobe Dynamic Linked clips to After Effects.
    I cannot edit these while unrendered.
    If I take the hours to render the data within the nested sequence, and then when moving that sequence in the main sequence, will Premiere have to re-render the initial data?
    Or, does it have a memory of the data that is rendered within the nested sequence so it won’t be as graphic intensive?
    Joseph Tese replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
