Activity Forums Apple Final Cut Pro Legacy Documentary film look
  • John Calhoun
    January 31, 2006 at 12:58 am
    Graeme, you are correct. It’s been a while since I did my tests and I confused de-interlace with the upper levels of flicker filter. You are also correct that de-interlace renders faster than strobe of one and I’ll use that instead. (… sorry i can’t purchase your filters yet! ;
  • Bill Kelly
    February 1, 2006 at 2:35 am
    I’ve done this technique also, and have been very pleased with the results.
    On the lower layer, set the deinterlace filter to “lower” and on the upper layer set it to upper. Reduce the upper layer to 50% opacity and then render.
Page 2 of 2
