Documentary and short film online using only FCS2???
Hi, there is a possibility for us to try to make an online for a documentary and a short film in the coming months. Some time ago I would have thought to send these projects to an online facility (Avid DS, Flame, Smoke…) now I am wondering if we could make those projects in-house using FCS2 (thinking here about Color).
Can we manage well if we buy a good decklink card for monitoring and a good Panasonic Broadcast monitor?… can we be getting close to results achieved before only with much more expensive equipment?
For the documentary we would be given a mix of SD DV Pal and HDV Pal. All of it 4:3 that needs to be converted to 16:9, color corrected and graded. The end exhibition format will be for Digital cinema (2K projector as far as we know). Can we upres with good enough quality using only FCS2? Do the scaling algorithms used by FCS2 for scaling are good enough, in comparison with those like Teragen (4 tap scaling, 16 tap scaling, etc etc)
For the short film we will be given source footage from the Panasonic AJ-HDX900, shot with a 35mm adapter. Footage ingested through firewire to DVCPRO HD. Would FCS2 give us the possibility of making a color grade using Color that would be good enough to make an online and rendering a Digital Cinema compliant 2K (maybe 4K?). Are the upres capabilities of FCS2 sophisticated enough?
Many questions, I know, but looking forward for a good debate 😉
Paulo
