Activity › Forums › Apple Final Cut Pro › “Document could not be open” Dialogue box appears
  • “Document could not be open” Dialogue box appears
    Posted by Rodney Johnson on October 31, 2012 at 1:16 pm
    Note: I’m an FCP 7 user and don’t use FCPX…I was given an FCPX project file from a client. Client is in FCPX version 10.0.5. My FCPX version is 10.0.6. When I try to open the project file I get a dialogue box that reads…
    The document “CurrentVersion.fcpproject” could not be opened. Open documents from within Final Cut Pro.
    Any thoughts?
    RJ
    Rodney Johnson replied 13 years, 11 months ago 2 Members · 2 Replies
  • Kyle Bass
    October 31, 2012 at 4:39 pm
    You don’t actually “open” Final Cut Pro projects, per se. Quit FCPX. Place the entire project folder into “Final Cut Projects” in the root of your external drive, or if you’re using the internal system drive (which you shouldn’t be) in ~/Movies/Final Cut Projects. Then re-open Final Cut and you should see the project in your project library.
  • Rodney Johnson
    November 2, 2012 at 4:27 am
    looking like it worked. Thank you. RJ
