Activity › Forums › Apple Final Cut Pro Legacy › do you use Motion project file or an export within FCP?
  • do you use Motion project file or an export within FCP?
    Posted by Todd Reid on January 24, 2009 at 8:10 pm
    I have found that when I make animated gfx in Motion and then bring the project file into FCP, I get extremely long renders, and overall sluggish performance.
    I’m running a 3GH octocore, with 8 GB RAM, OS 10.5.6 and FCP 6.0.5, normally use ProRes HQ timelines
    When I use the same gfx, but export out a lossless + alpha (even thou it doesn’t match my timeline settings), I get MUCH faster renders, and don’t notice any inherent sluggishness. So obviously whenever I make a revision, I go thru the export & re-render process, but this is still a smoother workflow for me.
    Even exporting a prores version (to try to eliminate the need for render) seems to give me some issues, so I stuck with what was working.
    How many members of the herd are getting similar results?
    How many are using the Motion projects with no troubles, or in particular, slowdowns?
    Todd Reid
    Senior Editor
    Digitized Media, Inc.
    Bret Williams replied 17 years, 8 months ago 2 Members · 1 Reply
  • Bret Williams
    January 24, 2009 at 9:37 pm
    I think that’s it’s pretty unanimous that motion projects take forever to render in FCP. And unlike a simple file, if you make simple adjustments to it like scale or opacity, you have to rerender the whole thing.
