Activity Forums AJA Video Systems Do you need Kona2 for DVCPROHD or IO is good?
  • Do you need Kona2 for DVCPROHD or IO is good?
    Posted by Sam on May 6, 2005 at 2:44 am
    A little confused
    I have been noticing that a lot of people are using DVCProHD especially if you don’t want to spend too much on storage. We have Lacie 1TB and 500 Big Disk FW800 Drives. According to posts here, they should be able to handle DVCProHD?
    Can you work with DVCProHD with the AJA IO or do you need Kona2 for the quality?
    Is the benefit of Kona2 really if you want to do HD-SDI (Varicam/HDCAM)?
    Is there any way of using the Kona2 and/or AJA IO to convert all footage to DVCPROHD? Convert all HDCAM/Varicam, BetaCAM all to DVCPROHD or is HDCAM/Varicam different and better formats and they should be editing and worked in their native modes?
    If the footage mostly Betacam SP and DVCAM. Is Kona2 a good investment? and is there any benefit of using the DVCPROHD codec (other than better graphics) for the edit.
    Sam
    Graeme Nattress replied 21 years, 4 months ago 4 Members · 3 Replies
  • Andy Edwards
    May 6, 2005 at 5:18 am
    If you need to do a bunch of conversions, then the Kona2 is the way to go. If you have all your footage on Panasonic varicam tapes, then just rent the AJHD-1200a deck and import all your footage via firewire directly into FCP without the AJA IO or Kona2. I did this last year just after NAB as the Kona2 was not shipping. I had all my HDCAM tapes dubbed to 1080i60 on Panasonic tapes and rented the deck. I had the entire 30 minute documentary edited on a single firewire drive in DVCPRO HD.
    Andy
  • Walter Biscardi
    May 6, 2005 at 12:15 pm
    Varicam footage IS DVCPro HD so whether you come in Firewire or SDI, it’s the same quality.
    HDCAM is more of an uncompressed format, though not totallly, it’s something like 3:1 compressed but generally you capture that at native 1080i uncompressed.
    The Kona 2 features both upconversion (SD to HD) and downconversion (HD to SD) on the card which is fantastic when you’re working with the SD formats as you note. Really what I would do in your situation since it’s all SD material, is capture it at 8 or 10 bit uncompressed SD, edit the piece, then use the Kona 2 to upconvert the material to HD.
    Or, you can simply capture in DVCPro 50 which is a much better format than DV or DVCAM for graphics and just stay in the SD world which I’m pretty sure you can do with the Io.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Graeme Nattress
    May 6, 2005 at 8:02 pm
    Comparing HDCAM and DVCproHD to 4:4:4 uncompressed HD (all 1080) I came up with the following figures:
    HDCAM is 135mbps, which is a 11:1 compression over fully uncompressed.
    DVCproHD is 100mbps, which is a 14:1 compression over fully uncompressed.
    However,
    Of the 6220800 pixels across the 3 components of fully uncompressed,
    HDCAM records 2592000 of them, or about 42% of them.
    DVCproHD records 2764800 of them, or about 45% of them.
    But if you look at the ratio between recorded luma pixels and recorded chroma pixels,
    HD 4:4:4 YCbCr for every 1 luma pixel there are 2 chroma pixels.
    HDCAM for every 1 luma pixel there are 0.66 chroma pixels.
    DVCproHD for every 1 luma pixel there are 1 chroma pixels.
    So yes, HDCAM is less compressed than DVCproHD, but it also records less of the pixels from the uncompressed image, although it does this by recording more luma resolutio and a lot less chroma resolution. We can now look at the number of bits per pixel that is used to compress the image:
    HDCAM uses 1.82 bits per pixel and
    DVCproHD uses 1.26 bits per pixel
    Because both formats balance the compression parameters very differently, especially the lower spatial luma resolution recorded by DVCProHD, it’s very hard to compare them directly just looking at the figures. A lower spatial resolution filtered down from the original 1920 to 1280 should be easier to compress because a) it’s smaller and b) will have a higher degree of super-sampling and hence have less sharp edges which cause DCT codecs bother. Also, the lower spatial resolution of DVCproHD might correlate better to the limitations of lens resolution on the camera, and this will especially be the case as we get more 1/3″ chip cameras using the DVCproHD codec.
    Hope this is enlightening and if anyone has more facts or figures to add, that’d be great.
    Graeme
    http://www.nattress.com – Film Effects for FCP
