Do we expect an update to Boris Red to support Vegas Pro 9?
Posted by Fotis Vassis on April 27, 2009 at 2:16 pmJust preordered the Vegas Pro 9 and I am curious if we need an update for Red to support it, or is it enough to just move the plugins to the new folder of the v.9?
Interchefs Culinary Club
The Interactive Gourmet ExperiencePeter Mcauley replied 17 years, 5 months ago 2 Members · 5 Replies -
Peter Mcauley
April 27, 2009 at 5:20 pmHi,
I think you should be okay but just to be on the safe side I’m checking with QA.
Cheers,
Peter.
Fotis Vassis
April 27, 2009 at 5:54 pm -
Peter Mcauley
April 27, 2009 at 8:19 pmQA is an abbreviation for Quality Assurance. We have a group of “QA” engineers whose job it is to rigorously test all of our software before it is released. I checked with them and they tell me that the current version of RED 4 will operate as expected in Vegas Pro 9.
Cheers,
Peter.
Fotis Vassis
April 28, 2009 at 1:15 pmThanks for your answer. By the way, I always wanted to ask you this
Some months ago I downloaded a trial version of Color Finesse to try it with Red. Unfortunatelly it doesn’t work and comes up with some errors ( I am not in front of the workstation now to tell you exactly). Have you ever tried a (probably) earlier version of that plugin which works? (referring to the color finesse plugin, installer for other compatible applications)
The Interactive Gourmet Experience -
Peter Mcauley
April 28, 2009 at 4:32 pmHi,
I believe that the Color Finesse plug-in was a little problematic insofar as bringing up the interface for the filter. If it’s important to your workflow to use this filter in RED then I would like to ask you to please send in a detailed report to support@borisfx.com and we’ll see if there is a way that we can engineer a solution for the next update of RED.
Cheers,
Peter.
