Activity Forums Audio Do people here feel safe buying used mics?
  • Do people here feel safe buying used mics?
    Posted by Noam Osband on July 22, 2011 at 12:05 am
    When it comes to gear, I usually buy new electronics and used for something mechanical like a tripod. I’m looking for a shotgun, and dont mind paying more for a gun I can use for many, many years. I’m thinking of the NTG-3 or the MKH-416.
    I found a used MKH-416 on B&H and am considering it. That said, I am a bit wigged out over buying used electronics for the long haul. Thoughts?
    David C jones replied 15 years, 1 month ago 4 Members · 10 Replies
  • 10 Replies
  • Eric Toline
    July 22, 2011 at 12:48 am
    Don’t be wigged out. I’ve bought all of my top line mics used. B&H should have some kind of testing period & or warrenty. Buy the mic and don’t sweat it.
    Eric
  • Sam Lesante jr.
    July 22, 2011 at 12:50 am
    B&H is a pretty reliable store. Did they say if there was anything wrong with the mic since it is under the “used” items? I assume that they offer a refund or return with used stuff.
    I have had a 90% approval rating with them. The only thing that I had a problem with from them is there brand of XLR’s keep cutting out on me.
  • Eric Toline
    July 22, 2011 at 12:57 am
    It’s the soldering in the XLR connector that causes the cutting out. Buy Canare cable & Neutrik connectors and build your own if you know how to solder.
    Eric
  • Sam Lesante jr.
    July 22, 2011 at 1:07 am
    We checked and even resoldered but they still did not work.
  • Eric Toline
    July 22, 2011 at 1:26 am
    Could be a break internally but who knows? Run a continuity test with a multi-meter and see if the pin to pin wiring is the same on both ends. See if you can return it for a replacement if required.
    Eric
  • Sam Lesante jr.
    July 22, 2011 at 1:33 am
    Thanks again…will run test…they only offer return if we get the same xlr.
  • Eric Toline
    July 22, 2011 at 1:34 am
    I assume other cables work fine with the same setup?
    Eric
  • Sam Lesante jr.
    July 22, 2011 at 1:51 am
    Nope…all four cut out
  • Eric Toline
    July 22, 2011 at 3:43 am
    I assume you mean all 4 from B&H? I find that hard to believe. Have you tried any of the suspect cables in another system. Have you tried an xlr cable not from B&H? Would you explain the setup you’re using that’s causing you problems? Perhap’s it’s not the cable but some interconnect or settings issue.
    Eric
  • David C jones
    July 22, 2011 at 6:26 pm
    I bought two 50′ xlr’s from b&h and one or both were bad. However, I sent them to the manufacture (Audio Technica) and they sent me two new ones. It was a manufacture issue.
    Dave J
