Activity › Forums › Adobe Premiere Pro › Do not see a way to export to MPEG4
Posted by Scottsdigitalphoto on January 12, 2007 at 9:02 pmI do not see a way to export to an MPEG4 with mpeg2 audio in PP 2.0. The QT options do not seem to offer a way to do this.
Can some one help?
Kronos Malden replied 18 years, 7 months ago 4 Members · 9 Replies -
Aanarav Sareen
January 12, 2007 at 10:16 pmPremiere Pro does not export to MPEG4 content directly. 🙁
– Aanarav
Aanarav Sareen
premiere@asvideoproductions.com
https://www.asvideoproductions.com/techtalk -
Scottsdigitalphoto
January 13, 2007 at 2:35 pmCan you reccomend a conversion software? If so, what would be the best format to convert from – like mpeg2, avi, ect
Scott -
Pedigree-punk
January 13, 2007 at 6:26 pmFor heavy use I’d recommend Sorenson Squeeze first, then Canopus Procoder – I use both to good effect. If you are working with DV it would be best to export a DV avi for conversion in Squeeze / Procoder. For a much cheaper (but almost certainly slower and perhaps more limited) option it might be worth taking a look at upgrading your Quicktime player to Quicktime Pro – Not sure if QT Pro likes big .avi files much, I’ve heard the encodes can take quite a while – maybe an export to a Quicktime DV file from Premiere would be the best option before encoding to MPEG4 in QT Pro. HTH.
In order to discover new oceans, man has to leave sight of the shore. -
Aanarav Sareen
January 14, 2007 at 7:30 amDepends on what you want to do. But, the 2 frequently used applications are:
a) Sorenson Squeeze
b) Canopus Procoder– Aanarav
Aanarav Sareen
Scottsdigitalphoto
January 14, 2007 at 2:36 pmThanks,
yes I am working with DV files in standard and 16:9 formats. -
Scottsdigitalphoto
January 14, 2007 at 3:04 pmI am shooting HDV on DV tapes using Sony Z1Us. The footage is being used for webmercials.
So, should I export to an avi file, the use the reccomended programs to go to a MPEG4?
Scott -
Pedigree-punk
January 14, 2007 at 9:15 pmSo you are Shooting HDV – are you editing HDV or DV? If you downconverting to DV from the Z1 and capturing/editing DV then a DV avi is definitely the way to go – even if you are editing HDV it is probably the most straightforward way to go IMHO.
Scottsdigitalphoto
January 15, 2007 at 2:41 amEditing in HDV. If I need somthing in DV, I just shoot it in DV and bypass the convert. I will look for the software and go with the avi.
Thanks for your suggestions.
Kronos Malden
February 11, 2008 at 3:35 pmAdobe Premiere Pro CS does export out to MP4, it under the Adobe Media Encoder under the option of H.264, look through the settings and you’ll be able to change the output file to MP4. Good luck.
