Activity Forums Adobe After Effects Do MXF files work in After Effects? Can’t open these files
  • Do MXF files work in After Effects? Can’t open these files
    Posted by Joe Bags on April 16, 2017 at 2:48 am
    We’re doing VFX for a client and they gave us a drive of MXF video files to work on.
    The MXF files open just fine in premiere, but I tried it in After Effects and it says it’s an unrecognized format.
    How do you work on MXF files in after effects?
    Mark Thompson replied 9 years, 5 months ago 2 Members · 1 Reply
  • Mark Thompson
    April 16, 2017 at 7:21 am
    Joe,
    After Effects does support Mxf files, I use Sony cams and that’s all they produce. What version of After Effects are you using?
    I just did a quick check using AE 2017 and it at least will load and display.
    However Mxf is a container format, so you need to determine the format of the essence. A quick way to do that is to use Premiere Pro to look at the properties on that clip. Alternatively use G-Spot or similar to have a look.
    For example I just looked at the properties on an Mxf clip:
    File Path: K:\AlisonPod2\Media\XDROOT\Clip\726_0107.MXF
    Type: MXF
    File Size: 371.25 MB
    Image Size: 1920 x 1080
    Frame Rate: 25.00
    Source Audio Format: 48000 Hz – 24 bit – 8 channels
    Project Audio Format: 48000 Hz – 32 bit floating point – 8 channels
    Total Duration: 00:00:25:02
    Pixel Aspect Ratio: 1.0
    MXF File details:
    Wrapper type: MXF OP1a (type: SingleItem SinglePackage MultiTrack Stream Internal)
    File generated by: Sony, Mem (2.00)
    AVCI 100
    Sony bitstream format
    VR Projection: None
    Depending on what you find you may need to transcode to a format that is does support.
