Activity Forums Adobe Premiere Pro Do more clips/files add to render time?
  • Do more clips/files add to render time?
    Posted by Jason Johnson on March 15, 2011 at 4:38 am
    So I just did a pretty basic edit, a little over 2 minutes. 720/60p – no fancy effects..
    It’s taken well over 30 minutes to render..It seems to be going really slow.
    I’ve had more complex edits, including a longer duration project,with multiple after effects compositions render faster than this.
    I’m using about 15+ clips or so.. Probably the most I’ve used in a single project …Does having so many clips make the render slower?
    What gives? I’ve changed nothing since the last time I’ve used it…??
    Jeff Pulera replied 15 years, 6 months ago 3 Members · 3 Replies
  • Jon Barrie
    March 15, 2011 at 6:16 am
    Have you set export to a different size or hit the tick box for Maximum Quality? That will make an edit take way longer.
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Jason Johnson
    March 15, 2011 at 8:51 am
    I always do max render quality..and I always export to the same resolution I edit it..
    maybe it having so many clips does add to render time, because I havent changed any settings from my last edit..It just seems slower rendering…1 pass is taking longer than 2 pass on a previous edit…wonder what the deal is..
  • Jeff Pulera
    March 15, 2011 at 1:43 pm
    Max Quality doesn’t always help really, it is more useful when scaling the video. If staying at the same size, try without and I bet you will be happy with the result…and the huge time savings.
    Jeff Pulera
    Safe Harbor Computers
