Activity › Forums › Adobe Encore DVD › Do I need to do anything special to burn a 8.5 dual layer DVD?
  • Do I need to do anything special to burn a 8.5 dual layer DVD?
    Posted by Art White on December 12, 2013 at 4:49 am
    I just got CC but I can’t dynamic link from Premiere because I upgraded from CS5 and use Encore CS5 to burn DVDs but I’m way over 4.7gb. I’ve never used a 8.5 GB dual layer. Encore gives me the option with my burner. Any special instructions for burning and playing a dual layer?
    Art
    Stan Jones replied 12 years, 9 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jeff Pulera
    December 12, 2013 at 3:57 pm
    Hi Art,
    How long is the video? You may not need a DL disc – might be as simple as lowering the bitrate. DL discs come with a lot of headaches, such as getting the Layer Break to work properly, compatibility issues with players, more expense, etc.
    When manually encoding the MPEG-2 DVD file, use 560/minutes = bitrate, or find an online bitrate calculator app and plug in your specifics.
    Jeff Pulera
    Safe Harbor Computers
  • Art White
    December 12, 2013 at 4:38 pm
    Jeff,
    Thanks. I did some looking and learned how to lower the bit rate in Adobe Media Encoder, which I’ve never used before. The video wasn’t that long but I experimented with 4 HD cameras this time for a pageant and it ended up being 6.6GB, something I’ve never experienced before. I bought a few DL DVD’s and you are right. They don’t give them away. I’m burning one now as a backup and learning experience in case I have to use them.
    Thanks for the good contact,
    Art
  • Art White
    December 12, 2013 at 5:42 pm
    Actually, I can’t get the DL to burn with an error after ordering files, before building file systems, sorting I get the access denied. Never seen that one before
  • Stan Jones
    December 12, 2013 at 6:21 pm
    Be sure you run “as administrator” (for PC). Not sure what you call it on Mac. This is different than running under an account with administrative rights.
    Stan Jones
  • Art White
    December 12, 2013 at 6:35 pm
    You mean right click on the Encore project and run as? I’ll try that in a bit
    Artis White, Producer
    Flex Media LLC
    Studio:
    4983 Sunset Drive
    Perrinton, MI 48871
    Office: 517 323 8375
    flexmedia.tv
  • Stan Jones
    December 12, 2013 at 6:50 pm
    Yes, “run as.” If that is it, you can set it to do that always. With Encore, it is a good idea whether doing du al layer or not. But it has been a deal breaker for dual layer.
    Stan Jones
  • Art White
    December 12, 2013 at 7:39 pm
    Good call Stan,
    Burned just fine after that. Odd that was the problem but glad it was!
    Thanks Much
    Art
    Flex Media LLC
    Studio:
    4983 Sunset Drive
    Perrinton, MI 48871
    flexmedia.tv
  • Stan Jones
    December 12, 2013 at 8:07 pm
    Excellent!
    Stan Jones
