Do I need to convert wav to aiff?
I’m editing a music video in FCP7 and the audio for the song is a wav file. I opened up the file in a program I have to see the properties and it said format is pcm_s24le, sample rate 441000 Hz, and bit rate 2117000 bps. I’ve read you’re supposed to convert wav to aiff in FCP and I’ve also heard you can edit using wav. I just wanted to ask the pros on here for an answer. Thanks!
