Activity Forums Avid Media Composer Do I need original file?
  • Do I need original file?
    Posted by Leo Pepperrell on May 2, 2013 at 12:05 pm
    Firstly, sorry I’m a bit of a noob at the moment so this question may sound pretty stupid but:
    Once ive imported my file (.mov) into avid it creates a .MXF file (right?), so do I need that original .mov file that I imported or could I theoretically just delete it? (I dont want to delete it but im just wondering)
    I’m only thinking this because I want to move all my original .mov files onto another hardrive that I won’t have much access too, but I dont want to have to go through a re-linking process if this doesnt work.
    Leo Pepperrell replied 13 years, 4 months ago 2 Members · 2 Replies
  • Shane Ross
    May 2, 2013 at 5:03 pm
    When you import into Avid…and create MXF media…you can then remove the original files. The only time Avid references those is when they are connected via AMA.
    So you can import, and then remove the drive the originals are one and put it on a shelf..archiving it.
    Shane
    Little Frog Post
  • Leo Pepperrell
    May 4, 2013 at 10:21 am
    Thanks, simple but informative answer!
