Activity › Forums › Adobe After Effects › Do I need Illustrator installed to continuously rasterize?
Posted by Fenton Dyer on August 11, 2014 at 8:49 amTopic says it all really. Tried all the other tips on other threads but can’t continuously rasterize. So should I install Illustrator to do it?
John Cuevas replied 12 years, 1 month ago 2 Members · 3 Replies -
John Cuevas
August 11, 2014 at 2:06 pmNo, you don’t need it installed. You need a vector image, eps/ai files are generally vector. And then makes sure the continuously rasterize button is pressed.
Here’s some vector images, if they don’t scale properly, then you are doing something incorrectly: 7855_vectorimages.ai.zip
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Fenton Dyer
August 11, 2014 at 9:10 pmHi,thanks for your reply. Yeah those scale correctly. Is it anything to do with the save settings in Illustrator?
John Cuevas
August 12, 2014 at 2:01 amNo, the settings shouldn’t matter, as long as you are using vector images.
Do you have bitmapped(pictures) in your illustrator files? If they are bitmapped doesn’t matter if you save them as eps or ai, they are still bitmapped images and won’t continuously raster.
