Activity Forums Adobe After Effects Do I need any configuration adding 4 GB more to be total of 8GB?
  • Do I need any configuration adding 4 GB more to be total of 8GB?
    Posted by John Suzuki on August 3, 2008 at 5:06 am
    Hello all,
    I running AE CS3 on Vista 64-Bit with 4GB and I’m planning on adding 4GB more to be total of 8GB.
    Do I need to confogure anything to add 4GB more or is it just as simple as adding the memory sticks in?
    Thanks for your help.
    J
    Brendan Coots replied 18 years, 1 month ago 3 Members · 4 Replies
  • Christian Wheel
    August 4, 2008 at 7:16 pm
    Nope, just plunk em in! You’re already on vista 64 so you should be fine.
    A single application (like AE) will still only be able to address a max of 4GB at a time though.
    —– Christian Wheel —–
    Radio Host, 104.3 MyFM, Los Angeles
    Audio Production & Imaging
    MS Visual Studio Developer
    After Effects Enthusiast
  • John Suzuki
    August 4, 2008 at 8:08 pm
    really? AE can only address 4GB max?
    Then, what’s the point of adding 4 more?
    I was mainly trying to speed up the AE though.
    Any thoughts?
    Thanks.
  • John Suzuki
    August 5, 2008 at 10:53 pm
    Hello again,
    Does anyone know if I can use 8gm Ram on AE CS3?
    I just added 4 more to be total of 8GB on my
    Intel Xeon CPU 3.00GHz 3.00 GHz
    64-bit
    AE CS3 still sees the 4 gb only when I render.
    I’m trying to render quicktime with Sorenson 3.
    Do I have to render multi frames to take adventages of all 8 GB?
    Any tips would be helpful.
    Thanks.
  • Brendan Coots
    August 5, 2008 at 11:40 pm
    You must use the Multiprocessing feature in AE CS3 to use more RAM. Multiprocessing silently spawns a new background instance of After Effects for each processor you have, provided you have at least 1-2GB RAM per CPU core. This is how it gets around the RAM limit per application, by spawning many instances of the application and combining the efforts of those instances.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
