Activity Forums Adobe Premiere Pro Do I need a Kona card instead of a video card upgrade? PC CS5.
  • Do I need a Kona card instead of a video card upgrade? PC CS5.
    Posted by Steve Mac kenzie on May 4, 2012 at 4:13 pm
    I have limited budget at this time. Enough for one card or the other and I am getting conflicting answers so I want to bring it to the editors… Thank you again since this is a follow up?
    The post house sent me footage ingested in AJA 10 bit uncompressed from a Teleciny in ’93. 3;2 pulldown, interlaced, 525 line in MOV. format. In properties the Data rate is 27.2 mb a second. I spoke to the builder of my system and they recommended upgrading to a Nvidia 4000 from my current NVIDIA Quadro FX1700 since I am having issues with seeing the titles jumping and some jagged edges on shots with angles. DO I need a Kona Card instead since that would directly handle the AJA injest or will the 4000 take care of it? I am looking for a price point under a grand so probably the KONA LHe Plus.
    Again I appreciate your time and experience in this!
    Chipset: Intel x58-GigabitLAN-(6) SATA 3.0Gbps-(2) SATA 6.0Gbps-1394a-(12) USB 2.0-(2) USB 3.0-(1) eSATA
    CPU: Intel Core i7-960 Quad Core Processor 3.20 GHz 4.8 QPI
    System RAM: 12GB (6x 2GB DDR3-1333)
    System Drive: 160GB Solid State Drive (SSD) +250MBps Read/+70MBps Write
    Spare Drive: 1.5TB SATA 3Gb/s NCQ 32MB Cache 7200RPM
    Display Adapter: NVIDIA Quadro FX1700 512MB DVI/DVI PCI-e
    Internal Video Raid: 2x 1.5TB SATA 3Gb/s NCQ 32MB Cache 7200RPM 3TB RAID-0
    Thank You for your input!
    Chris Borjis replied 14 years, 4 months ago 2 Members · 5 Replies
  • Chris Borjis
    May 4, 2012 at 4:19 pm
    what does the footage look like when you open it with quicktime?
    hit clover+I
    what does it say the codec is?
    by the way you describe it sounds like a low-quality downconvert
    from 720P to DV footage.
    the data rate should be a heckuva lot more than 27mbps if its uncompressed.
    If thats the case, no card upgrade will solve that.
    They will need to provide you with a high quality down-convert
    with uncompressed codec. Not DV.
  • Steve Mac kenzie
    May 4, 2012 at 4:56 pm
    Here is the information on the clip. Thank you again!
    Format: Ajav210, 654 X 486 Millions
    24 bit integer (Little Endian), Descrete-0 48,000 Khz (4 times for each audio track)
    Movie FPS 29.97
    Playing FPS – varies + 1 or -…
    Data Rate 228.37
    Normal size 655 X 486 Pixels
    Current Size 655 X 486
  • Chris Borjis
    May 4, 2012 at 5:16 pm
    that is uncompressed (228 data rate)
    I’m puzzled by the odd size of 655×486
    does it look the same (bad) when played with quicktime player (not from premiere)
  • Steve Mac kenzie
    May 4, 2012 at 5:34 pm
    I see heavy interlacing. These were from the D2 from a 1993 Teleciny. I am puzzled by the size as well since everywhere else the clip is listed as 720 X 486. The Aspect ratio looks normal as well. When I try to get it to play in my system full res it does not work at this point. When I pull into a sequence it is obviously down converting and causing the issues.
  • Chris Borjis
    May 4, 2012 at 5:52 pm
    maybe open in quicktime and save as ProRes or some other codec
